VAGNER *AG* Опубликовано: 7 ноября 2021 VAGNER Поделиться Опубликовано: 7 ноября 2021 СКАЧАТЬ Advantage Of 2.80 : - Add more car models - Remove Bugs - Reduce 80% Wake Up Error - Fix Checksum Error - Fix RSA Error - Fix Unmatched Key Error - Pcr2.1 Unlock Corrected - OBD2 edc15v edc15p edc15vm No Problem - Writing without problems At edc17 VAG - Optimize Running Speed - EU Online Version KESS V5.017 support - It supports More 140 Protocols Than the HW V4.036 KESS. - You can use it Online and it will not damage the hardware. - SW support multi-languages:English, German, Spanish, Italian, Portuguese, French - KESS V4.036 no token limited for some car, has token limited for some other car. - KESS V5.017 has no token limited for all vehicles ! - Working System: Windows XP Professional /Win7 / Win 8/ Win 10 - With coverage of all major brands and protocols including Line, CAN, EDC17 and MED17 and for Ford J1850. KSuite V2 is everything you need to work as a successful tuner at a very affordable price. - Read and write ECU via OBD2 port directly, no need disassemble ECU from the car, easy to use How to install : 1.Extract Ksuite 2.80.rar 2.Open folder Driver 3.Open Driver_USBDEVICEDRV.EXE to install the device software 4.Open vcredist_x86.exe to install 5.Send Ksuite_2.80.exe to desktop 6.Open Ksuite shortcut desktop and DONE. Ссылка на комментарий Поделиться на других сайтах Больше способов поделиться...
