    Последняя версия Ksuite V 2.80 для китайских клонов Kess
    СКАЧАТЬ
    Advantage Of 2.80 :
    - Add more car models
    - Remove Bugs
    - Reduce 80% Wake Up Error
    - Fix Checksum Error
    - Fix RSA Error
    - Fix Unmatched Key Error
    - Pcr2.1 Unlock Corrected
    - OBD2 edc15v edc15p edc15vm No Problem
    - Writing without problems At edc17 VAG
    - Optimize Running Speed
    - EU Online Version
    KESS V5.017 support
    - It supports More 140 Protocols Than the HW V4.036 KESS.
    - You can use it Online and it will not damage the hardware.
    - SW support multi-languages:English, German, Spanish, Italian, Portuguese, French
    - KESS V4.036 no token limited for some car, has token limited for some other car.
    - KESS V5.017 has no token limited for all vehicles !
    - Working System: Windows XP Professional /Win7 / Win 8/ Win 10
    - With coverage of all major brands and protocols including Line, CAN, EDC17 and MED17 and for Ford J1850. KSuite V2 is everything you need to work as a successful tuner at       a very affordable price.
    - Read and write ECU via OBD2 port directly, no need disassemble ECU from the car, easy to use
    How to install :
    1.Extract Ksuite 2.80.rar
    2.Open folder Driver
    3.Open Driver_USBDEVICEDRV.EXE to install the device software
    4.Open vcredist_x86.exe to install
    5.Send Ksuite_2.80.exe to desktop
    6.Open Ksuite shortcut desktop and DONE.
