    Установка AMI (Audi Music Interface) MMI 3G
    • Установка AMI (Audi Music Interface) MMI 3G
    Содержание:
    General advice .................................................. .................................................. .....................................1
    Safety Instructions...................................... .................................................. ............................................2
    References of legal regulations for operation .................................................. .........................................2
    Note for factory fitted AUX IN .................................................. .................................................. ...............2
    Installation instruction....................................... .................................................. ......................................3
    Connection MMI 3G main unit .................................................. .................................................. ..............4
    Loom integration glove box............................................... .................................................. ......................4
    Diagnostic interface......................................... .................................................. .......................................5
    Coding............................................ .................................................. .................................................. ......5
    + полезная информация тут: ссылка.
