    DSG to Manual conversion
    hello friend
    sorry i write in english
    my russian very bad
    i need help in fixing some problem
    i work on VW and skoda cars
    these cars have deisel simos pcr2.1 ECU with DSG 7 transmission
    CAYC and CAYD engines
    i convert these cars from DSG to manual transmission coz DSG has alot
    of problems
    after i make it manual , i face a problem ,
    check engine light and glow plug and ABS lights are always ON
    when i check faults with VCDS on engine ECU and ABS ECU
    it says NO COMUNNICATION WITH TRANSMISSION ECU
    its becoz there is no longer DSG ecu
    can anyone help how to make these lights go off, and code car to manual transmission??
    i give who helo 100euro reward if his solution work for me
    i have VCDS , VCP+K and VAS
    thanks
    not even possible with DEALER ONLINE VAS ???
