Advantage Of 2.80 :
- Add more car models
- Remove Bugs
- Reduce 80% Wake Up Error
- Fix Checksum Error
- Fix RSA Error
- Fix Unmatched Key Error
- Pcr2.1 Unlock Corrected
- OBD2 edc15v edc15p edc15vm No Problem
- Writing without problems At edc17 VAG
- Optimize Running Speed
- EU Online Version
KESS V5.017 support
- It supports More 140 Protocols Than the HW V4.036 KESS.
- You can use it Online and it will not damage the hardware.
- SW support multi-languages:English, German, Spanish, Italian, Portuguese, French
- KESS V4.036 no token limited for some car, has token limited for some other car.
- KESS V5.017 has no token limited for all vehicles !
- Working System: Windows XP Professional /Win7 / Win 8/ Win 10
- With coverage of all major brands and protocols including Line, CAN, EDC17 and MED17 and for Ford J1850. KSuite V2 is everything you need to work as a successful tuner at a very affordable price.
- Read and write ECU via OBD2 port directly, no need disassemble ECU from the car, easy to use
How to install :
1.Extract Ksuite 2.80.rar
2.Open folder Driver
3.Open Driver_USBDEVICEDRV.EXE to install the device software
4.Open vcredist_x86.exe to install
5.Send Ksuite_2.80.exe to desktop
6.Open Ksuite shortcut desktop and DONE.
