Flash Discs - FLASHDATEN (Flash files, флэш файлы) для VAS PC, ODIS Engineering
• Insert the Update Programming CD into your PC. • Minimize or Run your VAS-PC. • Open "My Computer". • Open your "E:" Drive. A folder named "datflash" and a file named "label" will be displayed on the screen. • Minimize the window. • Open "My Computer" to open up a new window. • Open your "C:" drive. • Open the "SIDIS" folder. • Open the "Home" folder. • Copy/Paste the folder named "datflash" to the "Home" folder. • Close both open windows and maximize the VAS-PC screen. • Remove programming CD from your PC. • Activate Vehicle Self Diagnosis from your VAS-PC and select On Board Diagnostic (OBD). • Select appropriate address word for module being updated • At the bottom of the screen, select 019 – Update Programming. Note the files have to be for the control unit you are going to flash. The VAS-PC will NOT let you flash a TDi to a Transmission or a DSG to a 5sp auto. The file needs to be writen for that specific control unit. Some times there is a compainion file that the VAS-PC reads and make that dertimination of weither to flash or NOT!
