    how flash mib2 firmware with bin files
    finally,I find mib2 version 0728 firmware for China vehicle.
    But there are 5 files (4.pin,6.pin,CA.pin,mmx2,p0)
    I find /etc/shadow root password.
    root:YOeexrS1o01TU:1320853303:0:0
    user:!:1324310912:0:0
    YOeexrS1o01TU:C4meu6a0
    but the password can't work on 0618 firmware.
    So I can't enter telnet.
    Then I find some script.
    I have e100 dlink usb to eth device;
    mirrorlink=DENIED
    carlife=DENIED
    I open green menu to open swdl_option and force update map ,
    but my fsc will old and have some error.
    But I find if I record a address in 8 record point,I still can use nav and change address.
    About baidu carlife , I find some thing.
    smartphone_integrator BENCH_Startup 2 12454 [SI] Read appCodingInfo=coding is [carplay=1|gal=1|mirrorlink=1|carlife=1]
    Read appFecInfo=FecState: [gal=GRANTED|carplay=GRANTED|mirrorlink=DENIED|usb= GRANTED|carlife=DENIED], exlabFecInfo=GRANTED
    Anyone kowns about How to flash it without shell command and telnet password or can provide cn_p0038,p0618 firmware
    if you want this 0728 firmware,PM me,I provide the download link.
    Thanks very much!
    дачи всем. мои мастера 5K0352 ... мое устройство mst2 eu vw pq p 0351t Мне нужна версия, которая включает приложение для подключения Apple Car Play и голосовую команду и может быть установлена с USB. Буду рад, если вы поможете, товарищи
    Когда записываешь софт MST2_EU_VW_PQ_P0478T для mib2 на SD, надо только распаковать? Туда же закидывать image и pathc?
