    VAG ODIS 2.1.0
    Сообщение от S Service
    У него языковые базы просит ))
    ему наверное проекты закинуть надо.. так как сверху это название проектов..
    всё сервис 2.2.3 идёт.. и так установил 2.2.2 потом обновил прошивку балды на 2.20.20 потом снёс одис 2.2.2 установил 2.2.3 потом обновил балду на 2.20.23 и всё эврика всё работает полноценно..ну и плюсь лицуху до этого под свой ноут подправил
    вот инфа на энглише
    Since i have seen that you have problems with fw upgrade and install that, uninstall that ..... and so on i have made a pack with DRIVERS VAS5054 for X86 and x64 and with D-PDU API versions 1.20.20 extracted from ODIS 2.2.2 and 1.20.23 extracted from ODIS 2.2.3. Also inside you will see a log with firmware updated on these levels on VAS to compare with yours.
    This has been added to my vas collection also on Part 3 from HERE
    Like this you don't have to install and clean windows and so on. Monitor with a program only one installation so that when you are done with it you can clean that and install the other.
    Thanks to MrWolf that explained the procedure in an early post, here it is in detail:
    1. Connect VAS5054A to USB port and install Drivers
    2. Install D-PDU API
    3. Open Softing D-PDUAPI Test Application
    4. Select PDU-API Version - here choose your installed version
    5. Push Parse MDF File button
    6. On Select MVCI Module - now if all OK you should see your VAS
    7. Push PDUModuleConnect button
    8. Look at your VAS head and you should see it blinking.
    9. Wait for 30 sec or so and at the end if all OK you should have these lines:
    Return of PDUGetResourceIds:
    PDU_STATUS_NOERROR: PDU function call successful
    Number of matching resource IDs: 1
    Selected resource ID: 81
    10. Now look up on log and you should have:
    example for D-PDU API 1.20.23
    Module Short Name : VendorName='Softing AG' ModuleName='VAS5054' SerialNumber='082145725'
    Module Vendor Name : Softing Automotive Electronics GmbH
    Module HwName : VAS5054
    Module SerialNumber : 82145725
    Module FW Name : VeCom
    Module FW-Version : 2.20.23
    Module FW-Date : 8.9.2014 (Calendar week 36)
    Module PDU-API SW Name : Softing D-PDU API for VCIs
    Module PDU-API Version : 1.20.23
    Module PDU-API SW Date : 8.9.2014 (Calendar week 36)
    • Ответы 292
    Как всё сложно у Вас вместе с англичанами )).
    Обновил ,снес ,обновил...
    ну тут как-бы сами не рады к сожелению отвёркой и молотком не поможешь но иногда так хочиться... ну самое главное результат
    Жаль, что я не владеющих русским языком.
    Вот вам мои ссылки Александра работе postsetups и программ.
    Спасибо за размещение моей пояснил процедуру обновления.
    Здесь у вас есть ссылка на драйверы и API от одис комплект.
    Сообщение от fantomel
    Спасибо! Молодец!
    в настройках где база данных там есть одно место где didb инженер стоит заходим туда и выбераем папку выше где просто didb БЕЗ инженера!
    Поставил E 6.2.2 по этой схеме, вроде работает, но только по синезубу.
    Балда с OKI чипом прошилась 2.20.23, а другая балда без OKI совсем не видится как vas5054, только как com порт и не шьётся.
    Install PostSetup.
    Set the same as in ODIS-Service.
    Only "second run" is not necessary. So long not necessary.
    After installing Postsetup program will start and swear at not found on the base en_US.. It's OK. ))
    Close program.
    Do the following:
    Open folder C:\Program Files (x86)\ODIS_Engineering_622\DIDB.
    Next, go to the folder "data" and in all the folders with brands
    find files that contain the file name en_GB, and rename at en_US.
    Next, go to the folder "db" and find files that contain the file name en_GB, and rename at en_US.
    Now the program will see the desired database.
    The next step.
    Folder "DIDB_ENGINEERING" empty.
    More precisely, it will be a folder "data", and in the folder "data" empty folder "V".
    Next, there are two variants.
    First - full copy folder "data" and "db" folder in the "DIDB_ENGINEERING".
    But it is - superfluous expenditure of disk space.
    The second variant is more preferable.
    Delete all folders from "DIDB_ENGINEERING".
    From the folder "DIDB" make symlinks - of folders "data" and "db" in the folder "DIDB_ENGINEERING".
    Installation projects.
    Place the folder "Projects" in the root directory disk "C:\".
    Run ODIS-E.
    Menu "Admin" -- "General" -- "Diagnostic Data"
    "ODX Update index file 1" - Select "C:\Projets\AU\ODXUpdate.xml"
    "ODX Update index file 2" - Select "C:\Projets\VW\ODXUpdate.xml"
    "ODX Update index file 3" - Select "C:\Projets\SK\ODXUpdate.xml"
    Save.
    Exit the menu "Admin".
    Go to menu "Configuration" -- "ODX Update"
    Select all installed projects -- Start.
    All projects will be installed.
    Сообщение от theviy
    Балда, или как её там уже была с прошивкой 2.20.23, а другая балда без OKI совсем не видится.
    Install PostSetup.
    Close program.
    Do the following:
    The next step.
    Run ODIS-E.
    Save.
    синезуб выключи и потом от fantomel Меню пользователя fantomel-я сверху стени движок для 5054 там в рар папке на все системе он скинул..должно пойти потом с усб тоже...
    тут другая тема мне проекты новые нужны например шаран с 2011 года те которые с 6,2,2 они не полные.. кто может поделиться таким?
    Сообщение от theviy
    E 6.2.2 все накатываю PostSetup_622 всё пучком, а при старте прогы вылетают ошибки:
    ODS6501E. didb_GFS-e required for the application was not found.
    и т.д.
    didb_GFS-s
    didb_GFS-n
    didb_GFS-a
    didb_GFS-l
    didb_GFS-v
    didb_GFS-c
    didb_GFS-e.en_US
    didb_GFS-e.de_DE
    didb_GFS-s.en_US
    didb_GFS-s.de_DE
    didb_GFS-n.en_US
    didb_GFS-n.de_DE
    didb_GFS-a.en_US
    didb_GFS-a.de_DE
    didb_GFS-l.en_US
    didb_GFS-l.de_DE
    didb_GFS-v.en_US
    didb_GFS-v.de_DE
    didb_GFS-c.en_US
    didb_GFS-c.de_DE
    Чё делать?
    ребята,у меня такая же проблема,подскажите что делать
    из выше описанного не особо понял,разъясните пожалуйста
    Привет всем.Подскажите пожалуйста,будет ли работать VAS5054 с ODIS или адаптер заблокируется?
    Привет. Подскажите. Если шнур ставлю без дров. Ноутбук увидит шнурок. Или даже загораться лампочка не будет?купил только
    Сообщение от theviy
    и т.д.
    didb_GFS-s
    didb_GFS-n
    didb_GFS-a
    didb_GFS-l
    didb_GFS-v
    didb_GFS-c
    didb_GFS-e.en_US
    didb_GFS-e.de_DE
    didb_GFS-s.en_US
    didb_GFS-s.de_DE
    didb_GFS-n.en_US
    didb_GFS-n.de_DE
    didb_GFS-a.en_US
    didb_GFS-a.de_DE
    didb_GFS-l.en_US
    didb_GFS-l.de_DE
    didb_GFS-v.en_US
    didb_GFS-v.de_DE
    didb_GFS-c.en_US
    didb_GFS-c.de_DE
    Чё делать?
    Подскажи решил проблему?
    Сообщение от Голандец 26
    Скопируй из Одис сервиса эти файлы из папки db в папку db инжинерки
    По точнее путь
    та же проблему, не пойму куда скопировать.. вылетает ошибки эти и всё.. HELP!!
