    Front camera calibration problem (A5) for golf 7
    Hello everyone, I have a huge problem, I installed the front camera in my golf 7 I changed the windshield, I coded the camera, I calibrated with OBD 11 and then I I did it again with Odis.S but the calibration in statics is done perfectly well, but on the other hand nothing in dynamic, I rolled well several hours nothing is triggered, do you know what to do is hardened? Or if you know how to trigger it in dynamic? Thank you for answering me, I leave you the recorded data of my calibration
    Сообщение от nirvananils
    It`s actually a secret, some poeple can do static calibration wihout some equipment, just VCP or Odis
    Not static but dynamic calibration. its easy if you know how to and will save a lot of time at workshop
    I work for TEXA. In TEXA there is no dynamic calibration for VW, only static. You need to set the target correctly and press the button - Calibration. For all VAG groups, TEXA has only static calibration of both cameras and radars. Do you have a target?
    Сообщение от ISAT
    I have done dynamic calibration many times with Odis-E. So static is not needed but for workshops of course you need calibration board as they dont have access and knowlegde to do it in Odis-E.
    Сообщение от kreativ19
    Well, share your sacred knowledge with the people. How to do dynamic calibration on VAG?
    The initiator of the discussion left, leaving the dialettes, posing as specialists. The main answer is - I know, but I won't tell anyone. The usual situation on such forums.
