    Адаптивный круиз не доступен Touareg NF
    АСС (адаптивный круиз-контроль) перестало все работать
    VCDS недостатки
    Address 8B: Adaptive Cruise Control 2 Labels: SVO \ 4H0-907-561.clb
    Control unit order number: 7P6 907 541 A HW: 7P6 907 541
    System and / or version: ACC3 H13 0230
    Coding: 3F04010101
    Workshop number: WSC 31414 790 00001
    ASAM Dataset: EV_AdaptCruisContr2VW526 001004 (VW52)
    ROD: EV_AdaptCruisContr2VW526_001.rod
    VCID: 387F9EE183538C8A2D-806C
    The faults have been deleted
    3 defects found.
    17664 - Control unit defective
    B2000 00 - -
    [Extended UDS fault details are supported only by the current generation of interfaces (HEX-V2 and HEX-NET)]
    Confirmed - Tested since clearing memory
    fault information:
    Status of faults: 00000001
    Fault Priority: 1
    Frequency of defects: 1
    Control unit temperature: 33 ° C
    Terminal voltage 15: 9.902 V
    Velocity_vehicle_reference: 0 m / s
    Longitudinal_acceleration_vehicle_reference: 0.00 m / s²
    18176 - Control unit defective
    B2000 00 - -
    fault information:
    Fault Priority: 1
    18688 - Control unit defective
    B2000 00 - -
    fault information:
    Fault Priority: 1
    Address 13: Distance control Labels: SVO \ 4H0-907-561.clb
    Control unit order number: 7P6 907 561 A HW: 7P6 907 561
    System and / or version: ACC3 H17 0230
    Coding: 3F04010101
    Workshop number: WSC 22021 401 86144
    ASAM Dataset: EV_AdaptCruisContrVW526 001004 (VW52)
    ROD: EV_AdaptCruisContrVW526_001.rod
    VCID: 3A7B84E9BD5F9E9ADB-806E
    1 error found:
    92416 - Function restriction received by error value
    U1113 00 - 00
    fault information:
    Fault priority: 6
    Reset counter: 235
    Mileage: 359600 km
    Date: 2019.08.24
    Time: 16:23:03
    Control unit temperature: 28 ° C
    Terminal voltage 15: 11.970 V
    Velocity_vehicle_reference: -0.01 m / sec
    спасибо за любой совет
    Ну ,дак это Новогодние праздники !
    Подождать надо ...
    И у Вас в Словакии автосервисы заработают .
    Сообщение от mattock
    VCDS недостатки
    Coding: 3F04010101
    3 defects found.
    B2000 00 - -
    fault information:
    Fault Priority: 1
    B2000 00 - -
    fault information:
    Fault Priority: 1
    B2000 00 - -
    fault information:
    Fault Priority: 1
    Coding: 3F04010101
    1 error found:
    U1113 00 - 00
    fault information:
    Fault priority: 6
    Reset counter: 235
    Mileage: 359600 km
    Date: 2019.08.24
    Time: 16:23:03
    Ahoj. Mash v perdeli jednotku slave acc.
    Zmenit, nebo fleshovat....
    Я не знаю, если в этом форуме, разрешено писать на английском ?
    flash unit with odis-e ?
    Yes. Check flashdata
    Try this
    ACC radar in touareg have when replacing a used parts - component protection ?
    Yes, and need after replacing Calibrate
    i dont see
    write me
    Чтобы получить возможность просматривать вложения других пользователей на форуме, у Вас должно быть не менее 15 сообщение(ий). Сейчас у Вас 4 сообщение(ий).
    i dont see
    write me
    Write me @. Or tel number
    Нужно заменить левый радар или отказаться от АСС, если не на что купить.
    Железо и ПО должны быть идентичными на обоих радарах.
