    Audi Q7
    Audi Q7 2007. Module with burnt processor. The module is 4L0 910 560 D. Does a 4L0 910 551T module replace?
    Can someone help me please?
    See the block number for Bosch. For example 0261........If the number matches the blocks of the same gland , respectively, substitution is possible.
    Vou pedir este número e peço ajuda de novo. Muito obrigado
    Сообщение от вуглускр
    it's edc16 ecu. You can safely try to reflash it via bdm port. Don't forget to make full (flash&eeprom) backup first.
    Qual dos 2?
    Сообщение от Zaebasto
    it's MED9 ecu)
    Qual dos 2?
