    This program is not designed to work with diagnostic adapters .
    A more detailed description can be found in the accompanying documentation ( ElsaWin_Primenenie.pdf )
    Extras. Information: This distribution contains all the necessary components for installation : 4.0 setup, 4.10 update, the base Audi 05.2013, serial numbers , key generator , and installation instructions . All components are in the form of an easy to install and do not require additional software.
    installation Procedures:
    The main requirement before you install ElsaWin - established presence in the Adobe Reader. The minimum version - 5 (There is a distribution) or later.
    The order of installation is simple:
    1. Install setup 4.0
    2. Install the update 4.1 (not required - base lies with the kernel version 4.0)
    3. Set the base.
    Just need to install SVGView.exe - he needed to display elektroskhem.
    Name / password to login: admin / admin
    Detailed instructions for installing ElsaWin 4.0 and 4.1 of say2108 - in the catalog Documentacia
    http://dump.bz/storage1/1013/31SryTlng9TcrvJMnsZ6C7qQJktCVLqY.jpg
    http://ul.to/1shi9cwj
    http://ul.to/4112rovb
    http://ul.to/59d6a21n
    http://ul.to/64ceshy3
    http://ul.to/8cax6uk5
    http://ul.to/b9qxbuyj
    http://ul.to/egcpskh4
    http://ul.to/gnl115ui
    http://ul.to/h5bmr5lv
    http://ul.to/j7ziy03l
    http://ul.to/nh56kcdm
    http://ul.to/nyyvgix8
    http://ul.to/sas5lehj
    http://ul.to/u9p5t0o8
    http://ul.to/vsee2fbe
    http://ul.to/x9v3aqs7
    http://ul.to/xdlbl4y8
    http://ul.to/ydoc8aum
